搜索 | 用户支持
详细了解
why you not answer questions submitted here? :(
  • 5 个回答
  • 2 人有此问题
  • 1 次查看
  • 最后回复者为 cor-el
this a repeat question. last question was deleted. I think u are incompetent
被采纳的解决方案
Do you still have that problem with the missing location (address) bar?
Make sure that toolbars like the "Navigation Toolbar" and the "Bookmarks Toolbar" are visible: "View > Toolbars"
  • If items are missing then open the Customize window via "View > Toolbars > Customize" or via "Firefox > Options > Toolbar Layout"
  • If a missing item is in the toolbar palette then drag it back from the Customize window on the toolbar
  • If you do not see an item on a toolbar and in the toolbar palette then click the "Restore Default Set" button to restore the default toolbar set up.
Press F10 or tap the Alt key to bring up the "Menu Bar" temporarily if the Menu Bar is hidden.
定位到答案原位置 👍 0
所有回复 (5)
Sorry, this forum is short of helpers to answer questions.
Your previous question is here - https://support.mozilla.com/en-US/questions/890996?s=&r=1&as=s
I can see that , is sad
选择的解决方案
Thank you very much. It finally worked when I put in them manually with the customized window. Now I can use my firefox again. Cheers
You're welcome
